My server shows Zabbix icmp pinger processes more than 75% busy.
I tried changing zabbix_server.conf (current number of pingers is set to 1000)
but log shows, that only one is running.
Can anyone help me? How can I make zabbix use the config file when starting?
My config setting:
Best regards
Simon
1849:20131109:161446.253 Starting Zabbix Server. Zabbix 2.0.8 (revision 38017). 1849:20131109:161446.260 ****** Enabled features ****** 1849:20131109:161446.260 SNMP monitoring: YES 1849:20131109:161446.260 IPMI monitoring: YES 1849:20131109:161446.260 WEB monitoring: YES 1849:20131109:161446.260 Jabber notifications: YES 1849:20131109:161446.260 Ez Texting notifications: YES 1849:20131109:161446.261 ODBC: YES 1849:20131109:161446.261 SSH2 support: YES 1849:20131109:161446.261 IPv6 support: YES 1849:20131109:161446.261 ****************************** 1851:20131109:161446.506 server #1 started [configuration syncer #1] 1852:20131109:161446.506 server #2 started [db watchdog #1] 1861:20131109:161446.508 server #10 started [trapper #2] 1862:20131109:161446.508 server #11 started [trapper #3] 1863:20131109:161446.508 server #12 started [trapper #4] 1865:20131109:161446.508 server #13 started [trapper #5] [B] 1866:20131109:161446.508 server #14 started [icmp pinger #1] [/B] 1869:20131109:161446.509 server #15 started [alerter #1] 1872:20131109:161446.509 server #17 started [timer #1] 1877:20131109:161446.509 server #20 started [history syncer #1] 1849:20131109:161446.510 server #0 started [main process] 1878:20131109:161446.510 server #21 started [history syncer #2] 1860:20131109:161446.510 server #9 started [trapper #1] 1879:20131109:161446.510 server #22 started [history syncer #3] 1880:20131109:161446.510 server #23 started [history syncer #4] 1870:20131109:161446.510 server #16 started [housekeeper #1] 1881:20131109:161446.511 server #24 started [escalator #1] 1874:20131109:161446.511 server #18 started [http poller #1] 1882:20131109:161446.511 server #25 started [proxy poller #1] 1884:20131109:161446.511 server #26 started [self-monitoring #1] 1870:20131109:161446.519 executing housekeeper 1853:20131109:161447.183 server #3 started [poller #1] 1859:20131109:161447.186 server #8 started [unreachable poller #1] 1857:20131109:161447.188 server #6 started [poller #4] 1855:20131109:161447.186 server #4 started [poller #2] 1856:20131109:161447.190 server #5 started [poller #3] 1875:20131109:161447.191 server #19 started [discoverer #1] 1858:20131109:161447.233 server #7 started [poller #5]
My config setting:
### Option: StartPingers # Number of pre-forked instances of ICMP pingers. # # Mandatory: no # Range: 0-1000 # Default: # StartPingers=1000
Simon
